Zum Hauptinhalt wechseln
Kyvol Cybovac L20 Motherboard Replacement
Was du brauchst
  1. Kyvol Cybovac L20 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Begin with the device laying on a flat surface with the power button facing up.
  2. Kyvol Cybovac L20 Motherboard Replacement: Schritt 2, Bild 1 von 2 Kyvol Cybovac L20 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove both of the side brushes.
  3. Kyvol Cybovac L20 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
    • Remove the battery panel.
  4. Kyvol Cybovac L20 Motherboard Replacement: Schritt 4, Bild 1 von 2 Kyvol Cybovac L20 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Slightly lift the battery out of the compartment.
    • Disconnect the battery connector.
    • Completely remove the battery.
  5. Kyvol Cybovac L20 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove 8 screws from the device as shown.
  6. Kyvol Cybovac L20 Motherboard Replacement: Schritt 6, Bild 1 von 2 Kyvol Cybovac L20 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Lift base up and unplug any cable connected form the motherboard into the rest of the components.
  7. Kyvol Cybovac L20 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the 4 screws holding the motherboard in place.
    • Lift the motherboard up and out of the chassis.
Abschluss
ErickAmaya
97 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 46
