Einleitung
The sensor on the side of the Kyvol Cybovac L20 is designed to help with edge detection and prevent the vacuum from falling off any ledges. In event that this sensor malfunctions, start by wiping the sensor with a clean, dry cloth. If the problem persists, use this guide to replace the sensor.
Was du brauchst
Begin with the device laying on a flat surface with the power button facing up.
Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
Remove the battery panel.
Slightly lift the battery out of the compartment.
Disconnect the battery connector.
Completely remove the battery.
Lift the body away from the base and disconnect all connectors between the two halves.
Use a spudger or your fingernails to gently walk the white connector directly out of its port.
Remove the sensor.
