Einleitung
The TV turns off by itself after a while or the TV will not start, blown off capacitors could be the source off error.
  1. MAKE SURE THAT YOUR DEVICE IS UNPLUGED!
    • MAKE SURE THAT YOUR DEVICE IS UNPLUGED!
    • Open the case carefully while loosing the marked srews.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Check the power-board. If there are any blown-up capacitors, you should replace them.
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  4. Note: If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
    • Note: If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
Abschluss
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
9 weitere Nutzer haben diese Anleitung absolviert.
eugl18
561 Reputation
1 Anleitung geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 55
Insgesamt: 9,704
