Einleitung
The TV turns off by itself after a while or the TV will not start, blown off capacitors could be the source off error.
Was du brauchst
Check the power-board. If there are any blown-up capacitors, you should replace them.
For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
Insert the replacement capacitors and solder it. Check the poles!
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
