Zum Hauptinhalt wechseln
LCD X2gen Display disassembly
Was du brauchst
    1. LCD X2gen Display disassembly, Display: Schritt 1, Bild 1 von 1
      • X2gen 22 lcd Screen repair guide
      Frag FixBot
      Kommentar hinzufügen
    2. LCD X2gen Display disassembly: Schritt 2, Bild 1 von 1
      • Power board displaying the capacitors to be replaced
      Frag FixBot
    3. LCD X2gen Display disassembly: Schritt 3, Bild 1 von 1
      • Display viewed laying face down on the working table (my dining table)
      • Remove the 6 screws. 4 on the corners and 2 middle bottom.
      Frag FixBot
    4. LCD X2gen Display disassembly: Schritt 4, Bild 1 von 1
      • Remove front bezel by lifting softly starting from the middle and moving out to the corners.
      Frag FixBot
    5. LCD X2gen Display disassembly: Schritt 5, Bild 1 von 1
      • Top middle
      Frag FixBot
    6. LCD X2gen Display disassembly: Schritt 6, Bild 1 von 1
      • Front bezel removed.
      • Observe: the control board, bottom right.
      • exposed screws on both sides (4 left, 4 right) holding the LCD to the back cover.
      Frag FixBot
    7. LCD X2gen Display disassembly: Schritt 7, Bild 1 von 1
      • Prepare to remove the 4 screws on each side to lift the LCD. Do not try to remove it after unscrewing the 8 screws. There are cables connected on the back.
      • This pic shows the right side
      Frag FixBot
    8. LCD X2gen Display disassembly: Schritt 8, Bild 1 von 1
      • This pic shows the left side
      Frag FixBot
    9. LCD X2gen Display disassembly: Schritt 9, Bild 1 von 2 LCD X2gen Display disassembly: Schritt 9, Bild 2 von 2
      • Lift carefully about 2 inch to expose the back light connections, 2 pink and 2 white.
      • Slide the monitor to the left about 3-4 inch. to have access to the connections.
      Frag FixBot
    10. LCD X2gen Display disassembly: Schritt 10, Bild 1 von 1
      • Carefully, unplug both connectors
      Frag FixBot
    11. LCD X2gen Display disassembly: Schritt 11, Bild 1 von 2 LCD X2gen Display disassembly: Schritt 11, Bild 2 von 2
      • After removing the connectors, slide it about 3-5 inches to the right to have access to the data connector and ground
      Frag FixBot
    12. LCD X2gen Display disassembly: Schritt 12, Bild 1 von 1
      • Remove the data connector and ground.
      Frag FixBot
      • Lift display. Is now completely free
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Aleks
201 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 33
Letzte 30 Tage: 88
Insgesamt: 2,621
