Was du brauchst
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Gently insert the fingernail between the screen frame and the screen glass.
De-clipping one by one the fixing points of the frame surrounding the LCD screen
Completely detach the frame surrounding the LCD screen.
Mark the 2 upper fixing screws of the LCD screen. Unscrew them.
Mark the two lower fixing screws on the LCD screen. Unscrew them.
Gently lay the LCD screen on the keyboard.
Locate the connector on the LCD screen
Release the connection cable.
Remove the connector.
Once the connector is removed, completely remove the LCD screen.
To reassemble your device follow the following instructions in reverse order
100%
irlanda hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
