Zum Hauptinhalt wechseln
Einleitung
This guide will walk you through replacing the battery of your device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew the two screws using a Phillips #0 screwdriver.
    • Unscrew the two screws using a Phillips #0 screwdriver.
  2. Use a spudger to lift the back cover and remove it from the device.
    • Use a spudger to lift the back cover and remove it from the device.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Press along the opposite side to release the battery from the Laptop then remove.
    • Press along the opposite side to release the battery from the Laptop then remove.
  5. Remove the battery from the device.
    • Remove the battery from the device.
Abschluss
abdualmjeed Alabdurazzaq
471 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 99
