Zum Hauptinhalt wechseln
Einleitung
This guide will help you replace the hard drive of your device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew the two screws using a Phillips #0 screwdriver.
    • Unscrew the two screws using a Phillips #0 screwdriver.
  2. Use a spudger to lift the back cover and remove it from the device.
    • Use a spudger to lift the back cover and remove it from the device.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Unscrew the four screws around the Hard Drive using a Phillips #0 screwdriver.
    • Unscrew the four screws around the Hard Drive using a Phillips #0 screwdriver.
  5. Slide the hard drive over and remove it from the device.
    • Slide the hard drive over and remove it from the device.
Abschluss
abdualmjeed Alabdurazzaq
471 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 135
