Einleitung
This guide is about substituting the screw terminal of floor lamp, providing that the lamp socket is bad when normally trying to test the socket for power with a $5 circuit tester that lights off.
If you notice your lamp’s cords and plug are intact, or your lamp’s lighting bulb is properly functioning, then your lamp’s lighting socket may need to be replaced.
Was du brauchst
Use a Phillips screwdriver to remove the two 3 mm screws from the silver cover.
Pull down both the silver cover and the black screw terminal.
Separate the light bulb socket from the silver cover by pulling the silver metal hasp in right-downward direction towards the lamp shaft.
Replacing the screw terminal of the floor lamp is relatively easy, but be cautious to deal with the step of the substitution of the light socket.
