Was du brauchst
Use a Spudger to remove the two front plastic covers to reveal screws.
Insert a small flathead screwdriver into the hinge and separate hinge connection.
Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
Unscrew the four screws on the back case using a T6 Torx Screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
