Zum Hauptinhalt wechseln
LG 1010 LCD Screen Replacement
Was du brauchst
  1. LG 1010 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the cell phone and place face down on a flat surface.
  2. LG 1010 LCD Screen Replacement: Schritt 2, Bild 1 von 2 LG 1010 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. LG 1010 LCD Screen Replacement: Schritt 3, Bild 1 von 3 LG 1010 LCD Screen Replacement: Schritt 3, Bild 2 von 3 LG 1010 LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove battery and set aside.
  4. LG 1010 LCD Screen Replacement, Front  Cover: Schritt 4, Bild 1 von 2 LG 1010 LCD Screen Replacement, Front  Cover: Schritt 4, Bild 2 von 2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  5. LG 1010 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove two screws using a Torx T6 screwdriver.
  6. LG 1010 LCD Screen Replacement: Schritt 6, Bild 1 von 2 LG 1010 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Pry off the screen front cover with a small flathead screwdriver.
  7. LG 1010 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  8. LG 1010 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  9. LG 1010 LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
  10. LG 1010 LCD Screen Replacement, Back Cover: Schritt 10, Bild 1 von 2 LG 1010 LCD Screen Replacement, Back Cover: Schritt 10, Bild 2 von 2
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  11. LG 1010 LCD Screen Replacement: Schritt 11, Bild 1 von 2 LG 1010 LCD Screen Replacement: Schritt 11, Bild 2 von 2
    • Pull the back cover straight off the phone using your thumb and forefinger.
  12. LG 1010 LCD Screen Replacement, Keypad: Schritt 12, Bild 1 von 1
    • Pry off circuit board with a flathead screwdriver.
  13. LG 1010 LCD Screen Replacement: Schritt 13, Bild 1 von 1
    • Pull out flexible keypad.
  14. LG 1010 LCD Screen Replacement, LCD Screen: Schritt 14, Bild 1 von 1
    • The phone should now look like the picture to the left.
  15. LG 1010 LCD Screen Replacement: Schritt 15, Bild 1 von 2 LG 1010 LCD Screen Replacement: Schritt 15, Bild 2 von 2
    • Locate and detach the ribbon cable from circuit board.
  16. LG 1010 LCD Screen Replacement: Schritt 16, Bild 1 von 2 LG 1010 LCD Screen Replacement: Schritt 16, Bild 2 von 2
    • Remove the LCD Screen from the phone case and replace with a new LCD screen.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 3-25, Regan Fall 2010 Mitglied von Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 961
