Einleitung
Before completing this replacement guide, it is important to unplug the device. This replacement guide will show how to replace the speaker in the device.
Was du brauchst
Pry open the back case on the device with a plastic opening tool and remove it.
Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
Pry open the top part of the internal casing with the plastic opening tool and remove it.
Insert plastic opening tool under the plastic flap and lift the speaker out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
