Zum Hauptinhalt wechseln
LG 32CS560 Power Supply Board Replacement
Was du brauchst
  1. LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: Schritt 1, Bild 1 von 2 LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: Schritt 1, Bild 2 von 2
    • Lay the TV face down on a soft surface
    • Remove the base of the TV by unscrewing the 4 base screws.
    • There is no base on the picture, the position of the base is marked whit the red box.
  2. LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: Schritt 2, Bild 1 von 2 LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: Schritt 2, Bild 2 von 2
    • Remove the 15 Phillips head screws on the back of the TV.
    • Carefully remove the black plastic back panel of the TV to expose the electronics inside
  3. LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: Schritt 3, Bild 1 von 3 LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: Schritt 3, Bild 2 von 3 LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: Schritt 3, Bild 3 von 3
    • Carefully disconnect the three wire bundles attached to the power supply.
    • Remove the four screws holding the power supply in place.
    • Now you can lift out the Power Supply Board.
    • If the black cylindrical component marked with yellow seems to have expanded or is leaking liquid or goo, then the power supply board is definitely bad.
Abschluss
19 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-3, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-3, Donnelly Fall 2014
USFT-DONNELLY-F14S1G3
1 Mitglied
1 Anleitung geschrieben
Ein Kommentar
preciso duma destas power bord como fazer para ter
brun mendes - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 29
Letzte 30 Tage: 179
Insgesamt: 44,704
