Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Slide rear cover downward and lift off. You can now access the battery.
Gently lift battery from bottom. Battery should lift out easily.
Use PH00 screw driver bit to loosen and remove six screws
Use plastic opening tool to release the casing cover.
Run the tool along edge of phone.
Lift casing cover.
Use plastic opening tool or fingernail to lift rectangular piece up. The piece can be identified by the orange tape attached to it.
Ein weiterer Nutzer hat diese Anleitung absolviert.
