Zum Hauptinhalt wechseln
LG A275 Screen Replacement
Was du brauchst
  1. LG A275 Screen Replacement, Replacing the screen: Schritt 1, Bild 1 von 2 LG A275 Screen Replacement, Replacing the screen: Schritt 1, Bild 2 von 2
    • In order to begin replacing your screen, you should first power down your device and remove the battery.
  2. LG A275 Screen Replacement, Unhinging the screen: Schritt 2, Bild 1 von 2 LG A275 Screen Replacement, Unhinging the screen: Schritt 2, Bild 2 von 2
    • Take a very thin plastic/ metal prying tool and gently work your way around the phone. You should hear popping sounds as each lock is opened. Be very careful as you pry open the case as you could damage the LCD/Motherboard.
    • Hearing popping is a normal sound. You are not breaking your phone. You are simply popping the seals for the first time.
  3. LG A275 Screen Replacement, Putting the New Screen on: Schritt 3, Bild 1 von 3 LG A275 Screen Replacement, Putting the New Screen on: Schritt 3, Bild 2 von 3 LG A275 Screen Replacement, Putting the New Screen on: Schritt 3, Bild 3 von 3
    • Take your new screen and place it onto the front of the phone. Very gently apply pressure until you here the locks click into place.
    • Make sure all of your locking pins line up on your phone or it will not close all the way.
    • Be careful when removing the old cover. It could have jagged pieces of glass/ plastic.
Abschluss
Nicole
237 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-2, Wilson Spring 2016 Mitglied von IUPUI, Team 2-2, Wilson Spring 2016
IUPUI-WILSON-S16S2G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 24
Insgesamt: 337
