Zum Hauptinhalt wechseln
LG Aristo Screen Replacement
Was du brauchst
  1. LG Aristo Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Turn off the device and make sure you are working on a flat, lit surface.
  2. LG Aristo Screen Replacement: Schritt 2, Bild 1 von 2 LG Aristo Screen Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to pry off the back case.
  3. LG Aristo Screen Replacement: Schritt 3, Bild 1 von 3 LG Aristo Screen Replacement: Schritt 3, Bild 2 von 3 LG Aristo Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the SD and SIM cards by sliding the cards out with your finger.
  4. LG Aristo Screen Replacement: Schritt 4, Bild 1 von 3 LG Aristo Screen Replacement: Schritt 4, Bild 2 von 3 LG Aristo Screen Replacement: Schritt 4, Bild 3 von 3
    • Remove the battery by prying it up with a fingernail or opening tool from the bottom edge.
  5. LG Aristo Screen Replacement: Schritt 5, Bild 1 von 2 LG Aristo Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove the ten screws from the midframe with a Phillips #000 screwdriver.
  6. LG Aristo Screen Replacement: Schritt 6, Bild 1 von 2 LG Aristo Screen Replacement: Schritt 6, Bild 2 von 2
    • Pry up on the screen with a plastic opening tool.
    • Try to avoid using a metal spudger as shown in the images as it has the possibility to damage the screen.
  7. LG Aristo Screen Replacement: Schritt 7, Bild 1 von 2 LG Aristo Screen Replacement: Schritt 7, Bild 2 von 2
    • Detach the cables from the press fit connectors.
    • There are four connectors in total, they consist of two on the cameras, one on the ear jack, and the one attached to the motherboard.
    • You can lift them up with you finger or you can use tweezers (optional).
  8. LG Aristo Screen Replacement: Schritt 8, Bild 1 von 2 LG Aristo Screen Replacement: Schritt 8, Bild 2 von 2
    • Gently remove the motherboard.
  9. LG Aristo Screen Replacement: Schritt 9, Bild 1 von 1
    • Replace the screen.
Abschluss
To reassemble your device, follow these instructions in reverse order. I hope that these steps have helped you with your issue.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Gateway, Team S1-G5, Saknee Fall 2019 Mitglied von Gateway, Team S1-G5, Saknee Fall 2019
GCC-SAKNEE-F19S1G5
4 Mitglieder
1 Anleitung geschrieben
Ein Kommentar
Do i need Loca Glue to replace the outer Glass?
chuck - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 1,329
