Einleitung
This guide will show you how to open up your Blu-ray player and remove the disc drive, whether it is to install a new one or gain access to the disc drive's components like the reader and tray motor.
Was du brauchst
Remove the three black 3/16” Phillips #2 screws from the backside of the player.
With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
Unhinge the tabs that attach the front panel to the unit:
Two tabs on the disc drive
Two tabs on the left and right side of the player
Three tabs on the underside of the player
Pull panel away from case.
Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
With the front side facing you lift the front of disc drive and pull out to remove.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
