Einleitung
This guide will show you how to open up your Blu-ray player and remove the power cord if it is faulty and causing problems related to powering the device.
Was du brauchst
Remove the three black 3/16” Phillips #2 screws from the backside of the player.
With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
Detach the power supply cord from the brown logic board by pushing the locking clip on the connector, and pulling out.
Remove the power cord from the panel by carefully sliding it upwards from its seating.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
