Zum Hauptinhalt wechseln
LG BP220 Power Cord Replacement
Was du brauchst
  1. LG BP220 Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 2 LG BP220 Power Cord Replacement, Power Cord: Schritt 1, Bild 2 von 2
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
  2. LG BP220 Power Cord Replacement: Schritt 2, Bild 1 von 3 LG BP220 Power Cord Replacement: Schritt 2, Bild 2 von 3 LG BP220 Power Cord Replacement: Schritt 2, Bild 3 von 3
    • Beware of the capacitors as they may shock you when touched.
    • Detach the power supply cord from the brown logic board by pushing the locking clip on the connector, and pulling out.
    • The connector may be difficult to remove. Wiggling it while pulling out may help release it.
    • Remove the power cord from the panel by carefully sliding it upwards from its seating.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Bart Quicho
463 Reputation
3 Anleitungen geschrieben
UW Tacoma, Team 1-1, Rose Winter 2015 Mitglied von UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 2,626
