Zum Hauptinhalt wechseln
Einleitung
The back case of the phone holds the motherboard and back speaker. You need to disassemble the back to replace these items.
  1. On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward. On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. Lift and remove the battery.
    • Lift and remove the battery.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Remove the two screw covers at the top of phone with tweezers. Remove the two screw covers at the top of phone with tweezers.
    • Remove the two screw covers at the top of phone with tweezers.
  5. Remove the six Phillips #000 (3mm) screws.
    • Remove the six Phillips #000 (3mm) screws.
  6. Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone. The plastic side buttons fall out when you take the back cover off. The back cover is connected to the speaker by red and black wires.
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  7. Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
Abschluss
Kathrine Muirhead
347 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 4-27, Amido Fall 2013 Mitglied von Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 200
