Einleitung
This guide will teach you how to replace the motherboard on the LG CF360. Completing this task will allow you to replace the number pad, SIM card port, power connector, LCD connector, and camera all in one.
Was du brauchst
On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
Set the back cover with the speaker aside.
Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
With the plastic opening tool, gently pry the LCD connector from the motherboard.
Set the motherboard aside.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
