Zum Hauptinhalt wechseln
LG CF360 Rear Speaker Replacement
Was du brauchst
  1. LG CF360 Rear Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 LG CF360 Rear Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Rear Speaker Replacement: Schritt 2, Bild 1 von 1
    • Lift and remove the battery.
  3. LG CF360 Rear Speaker Replacement, Back Cover: Schritt 3, Bild 1 von 2 LG CF360 Rear Speaker Replacement, Back Cover: Schritt 3, Bild 2 von 2
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Rear Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Rear Speaker Replacement: Schritt 5, Bild 1 von 3 LG CF360 Rear Speaker Replacement: Schritt 5, Bild 2 von 3 LG CF360 Rear Speaker Replacement: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Rear Speaker Replacement: Schritt 6, Bild 1 von 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Rear Speaker Replacement, Rear Speaker: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to pry the speaker cover off of the phone.
  8. LG CF360 Rear Speaker Replacement: Schritt 8, Bild 1 von 1
    • Use the plastic opening tool to pry the speaker out of the back cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Annie White
262 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 4-27, Amido Fall 2013 Mitglied von Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Mitglieder
19 Anleitungen geschrieben
Ein Kommentar
Where can I buy the replacement parts?
Sarah Birkett - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 260
