Einleitung
How to remove the display screen from an LG CG180 cell phone.
Was du brauchst
Power down the cell phone by pressing and holding down the red "end call" button.
Slide the back cover down using your finger to remove the cover from the phone.
Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
Separate keypad from circuit board by turning it upside down and allowing it to fall off.
Once both clips are released, turn over the circuit board so that the display is facing upward.
Carefully lift the display from the left side and open to the right.
