Zum Hauptinhalt wechseln
LG CG180 Hardshell Case Replacement
Was du brauchst
  1. LG CG180 Hardshell Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Hardshell Case Replacement: Schritt 2, Bild 1 von 1
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Hardshell Case Replacement: Schritt 3, Bild 1 von 2 LG CG180 Hardshell Case Replacement: Schritt 3, Bild 2 von 2
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Hardshell Case Replacement: Schritt 4, Bild 1 von 1
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Hardshell Case Replacement: Schritt 5, Bild 1 von 1
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Hardshell Case Replacement, Hardshell Case: Schritt 6, Bild 1 von 1
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Hardshell Case Replacement: Schritt 7, Bild 1 von 1
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Hardshell Case Replacement: Schritt 8, Bild 1 von 2 LG CG180 Hardshell Case Replacement: Schritt 8, Bild 2 von 2
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Hardshell Case Replacement: Schritt 9, Bild 1 von 2 LG CG180 Hardshell Case Replacement: Schritt 9, Bild 2 von 2
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Hardshell Case Replacement: Schritt 10, Bild 1 von 1
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Hardshell Case Replacement: Schritt 11, Bild 1 von 1
    • The hardshell case is separated from the rest of the phone.
Abschluss
Cal Poly, Team 14-42, Regan Winter 2010 Mitglied von Cal Poly, Team 14-42, Regan Winter 2010
CPSU-REGAN-W10S14G42
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,765
