Einleitung
Use this guide to replace the keyboard of the LG CG225.
Was du brauchst
Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
Fast fertig!
Abschluss
