Zum Hauptinhalt wechseln
LG CU515 Motherboard Replacement
Was du brauchst
  1. LG CU515 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 LG CU515 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use your thumb to press down and slide off the back cover of the phone.
  2. LG CU515 Motherboard Replacement: Schritt 2, Bild 1 von 3 LG CU515 Motherboard Replacement: Schritt 2, Bild 2 von 3 LG CU515 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Take out the battery by levering it out towards the bottom of the phone.
  3. LG CU515 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  4. LG CU515 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  5. LG CU515 Motherboard Replacement: Schritt 5, Bild 1 von 3 LG CU515 Motherboard Replacement: Schritt 5, Bild 2 von 3 LG CU515 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
  6. LG CU515 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  7. LG CU515 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  8. LG CU515 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
Abschluss
Cal Poly, Team 21-55, Johann Spring 2013 Mitglied von Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 504
