Zum Hauptinhalt wechseln
LG CU515 SKU 64743 Device Battery Replacement
  1. LG CU515 SKU 64743 Device Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 LG CU515 SKU 64743 Device Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 LG CU515 SKU 64743 Device Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Locate the raised tab at the top of the back cover.
    • Holding the phone in one hand and using your thumb on your other hand, push down on the tab until the cover detaches from the phone.
    • Slide the cover down until it is completely removed from the phone.
  2. LG CU515 SKU 64743 Device Battery Replacement, Battery: Schritt 2, Bild 1 von 3 LG CU515 SKU 64743 Device Battery Replacement, Battery: Schritt 2, Bild 2 von 3 LG CU515 SKU 64743 Device Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    • Holding the phone in one hand and using your index finger on your other hand, remove the battery from the phone by prying it out at indention located at the bottom of the phone.
Abschluss
Josh Davis
301 Reputation
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 223
