Zum Hauptinhalt wechseln
LG Chocolate 3 Side Buttons Replacement
Was du brauchst
  1. LG Chocolate 3 Side Buttons Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
    Frag FixBot
    Kommentar hinzufügen
  2. LG Chocolate 3 Side Buttons Replacement: Schritt 2, Bild 1 von 3 LG Chocolate 3 Side Buttons Replacement: Schritt 2, Bild 2 von 3 LG Chocolate 3 Side Buttons Replacement: Schritt 2, Bild 3 von 3
    • Using your index finger lift and remove the battery from the phone.
    Frag FixBot
  3. LG Chocolate 3 Side Buttons Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
    Frag FixBot
  4. LG Chocolate 3 Side Buttons Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
    Frag FixBot
  5. LG Chocolate 3 Side Buttons Replacement: Schritt 5, Bild 1 von 2 LG Chocolate 3 Side Buttons Replacement: Schritt 5, Bild 2 von 2
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
    Frag FixBot
  6. LG Chocolate 3 Side Buttons Replacement: Schritt 6, Bild 1 von 1
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
    Frag FixBot
  7. LG Chocolate 3 Side Buttons Replacement: Schritt 7, Bild 1 von 2 LG Chocolate 3 Side Buttons Replacement: Schritt 7, Bild 2 von 2
    • Carefully remove the rear case from the phone.
    Frag FixBot
  8. LG Chocolate 3 Side Buttons Replacement, Side Buttons: Schritt 8, Bild 1 von 1
    • Use tweezers to remove the music button found on the side of the phone.
    Frag FixBot
  9. LG Chocolate 3 Side Buttons Replacement: Schritt 9, Bild 1 von 2 LG Chocolate 3 Side Buttons Replacement: Schritt 9, Bild 2 von 2
    • Use tweezers to remove the volume control buttons on the opposite side of the phone.
    Frag FixBot
Abschluss
Cal Poly, Team 12-35, Amido Spring 2013 Mitglied von Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 45
Insgesamt: 463
