Zum Hauptinhalt wechseln
LG Chocolate Sliding Mechanism Replacement
Was du brauchst
  1. LG Chocolate Sliding Mechanism Replacement, Battery: Schritt 1, Bild 1 von 2 LG Chocolate Sliding Mechanism Replacement, Battery: Schritt 1, Bild 2 von 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Sliding Mechanism Replacement, Back Cover: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Sliding Mechanism Replacement: Schritt 3, Bild 1 von 3 LG Chocolate Sliding Mechanism Replacement: Schritt 3, Bild 2 von 3 LG Chocolate Sliding Mechanism Replacement: Schritt 3, Bild 3 von 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Sliding Mechanism Replacement, Sliding Front: Schritt 4, Bild 1 von 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Sliding Mechanism Replacement: Schritt 5, Bild 1 von 2 LG Chocolate Sliding Mechanism Replacement: Schritt 5, Bild 2 von 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Sliding Mechanism Replacement: Schritt 6, Bild 1 von 2 LG Chocolate Sliding Mechanism Replacement: Schritt 6, Bild 2 von 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Sliding Mechanism Replacement: Schritt 7, Bild 1 von 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Sliding Mechanism Replacement, Sliding Mechanism: Schritt 8, Bild 1 von 1
    • Use a Phillips #00 to remove the 4 screws that hold the sliding mechanism in place.
  9. LG Chocolate Sliding Mechanism Replacement: Schritt 9, Bild 1 von 1
    • Remove sliding mechanism.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Thomas
91 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 19-46, Regan Winter 2013 Mitglied von Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 360
