Zum Hauptinhalt wechseln
LG CineBeam Lens Replacement
Was du brauchst
  1. LG CineBeam Lens Replacement, Bottom Plate: Schritt 1, Bild 1 von 1
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
  2. LG CineBeam Lens Replacement: Schritt 2, Bild 1 von 3 LG CineBeam Lens Replacement: Schritt 2, Bild 2 von 3 LG CineBeam Lens Replacement: Schritt 2, Bild 3 von 3
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
  3. LG CineBeam Lens Replacement, Motherboard: Schritt 3, Bild 1 von 3 LG CineBeam Lens Replacement, Motherboard: Schritt 3, Bild 2 von 3 LG CineBeam Lens Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
  4. LG CineBeam Lens Replacement: Schritt 4, Bild 1 von 2 LG CineBeam Lens Replacement: Schritt 4, Bild 2 von 2
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
  5. LG CineBeam Lens Replacement: Schritt 5, Bild 1 von 3 LG CineBeam Lens Replacement: Schritt 5, Bild 2 von 3 LG CineBeam Lens Replacement: Schritt 5, Bild 3 von 3
    • Lift the motherboard out of the casing.
  6. LG CineBeam Lens Replacement, Speaker: Schritt 6, Bild 1 von 2 LG CineBeam Lens Replacement, Speaker: Schritt 6, Bild 2 von 2
    • Use your fingers to lift the speaker from the casing.
  7. LG CineBeam Lens Replacement, Lens: Schritt 7, Bild 1 von 3 LG CineBeam Lens Replacement, Lens: Schritt 7, Bild 2 von 3 LG CineBeam Lens Replacement, Lens: Schritt 7, Bild 3 von 3
    • Turn the device over so the power button is facing up.
    • Using an iFixit opening tool, pry open the top of the plastic casing and remove it completely.
  8. LG CineBeam Lens Replacement: Schritt 8, Bild 1 von 2 LG CineBeam Lens Replacement: Schritt 8, Bild 2 von 2
    • Remove the three 6 mm screws holding the lens and LCoS assembly in place using a Phillips #00 screwdriver.
    • Remove the lens and LCoS assembly from the casing.
  9. LG CineBeam Lens Replacement: Schritt 9, Bild 1 von 3 LG CineBeam Lens Replacement: Schritt 9, Bild 2 von 3 LG CineBeam Lens Replacement: Schritt 9, Bild 3 von 3
    • Remove the 4 mm screws using a Phillips #00 screwdriver.
    • Pull the lens assembly off of the display assembly.
    • When putting in a new lens assembly, make sure the focus knob is on the correct side.
Abschluss
Abid Neron
243 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-5, Botvin Spring 2022 Mitglied von UMass Dartmouth, Team 1-5, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 342
