Zum Hauptinhalt wechseln
LG CineBeam Wi-Fi and Bluetooth Card Replacement
Was du brauchst
  1. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Bottom Plate: Schritt 1, Bild 1 von 1
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
  2. LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 2, Bild 1 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 2, Bild 2 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 2, Bild 3 von 3
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
  3. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: Schritt 3, Bild 1 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: Schritt 3, Bild 2 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
  4. LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 4, Bild 1 von 2 LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 4, Bild 2 von 2
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
  5. LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 5, Bild 1 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 5, Bild 2 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 5, Bild 3 von 3
    • Lift the motherboard out of the casing.
  6. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Speaker: Schritt 6, Bild 1 von 2 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Speaker: Schritt 6, Bild 2 von 2
    • Use your fingers to lift the speaker from the casing.
  7. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: Schritt 7, Bild 1 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: Schritt 7, Bild 2 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: Schritt 7, Bild 3 von 3
    • Turn the device over so the power button is facing up.
    • Using an iFixit opening tool, pry open the top of the plastic casing and remove it completely.
  8. LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 8, Bild 1 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 8, Bild 2 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: Schritt 8, Bild 3 von 3
    • Using an iFixit opening tool, remove the battery.
  9. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: Schritt 9, Bild 1 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: Schritt 9, Bild 2 von 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: Schritt 9, Bild 3 von 3
    • Using an iFixit opening tool, move the plastic clip on the right side of the board out of the way.
    • Using an iFixit opening tool, pry the Wi-Fi and Bluetooth card out of its socket.
Abschluss
John Dalton
393 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-5, Botvin Spring 2022 Mitglied von UMass Dartmouth, Team 1-5, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 168
