Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Most of the LG Cosmos 2 must be disassembled prior to replacing the buttons. Follow these steps to complete this task.
  1. Insert the plastic opener into the slot at the top of the device. Apply gentle pressure with the plastic tool to pop the back case off. Apply gentle pressure with the plastic tool to pop the back case off.
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. Use the plastic opener to lift, and remove, the device battery. Use the plastic opener to lift, and remove, the device battery. Use the plastic opener to lift, and remove, the device battery.
    • Use the plastic opener to lift, and remove, the device battery.
  3. Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. Use the plastic opener to pry the rear case loose. This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place. This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  8. Use the plastic opener to disconnect the ribbon cable. Use the plastic opener to disconnect the ribbon cable.
    • Use the plastic opener to disconnect the ribbon cable.
  9. Use tweezers to disconnect the two cables that attach the motherboard to the case. Note: Pull on the cables gently to prevent damage for future use.
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  10. Remove the motherboard from the front case.
    • Remove the motherboard from the front case.
  11. Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
  12. Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism. Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
  13. Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
  14. Use the plastic opener to pry open the front of the phone. Slip the ribbon cable through the slit to fully separate the two pieces.
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
  15. Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
  16. Detach the ribbon cable with the plastic opener.
    • Detach the ribbon cable with the plastic opener.
  17. Use the spudger to pry the metal piece loose. Remove the metal piece along with the two ribbon cables. Remove the metal piece along with the two ribbon cables.
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
  18. Flip the front of the phone over and the old option buttons will fall out.
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
Abschluss
Nick White
833 Reputation
8 Anleitungen geschrieben
Clemson, Team 13-1, Benson Fall 2013 Mitglied von Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 280
