Einleitung
Rear case replacement will only require the removal of the battery and six screws, but prying the case loose may take a few minutes.
Was du brauchst
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
