Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Rear case replacement will only require the removal of the battery and six screws, but prying the case loose may take a few minutes.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Insert the plastic opener into the slot at the top of the device. Apply gentle pressure with the plastic tool to pop the back case off. Apply gentle pressure with the plastic tool to pop the back case off.
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. Use the plastic opener to lift, and remove, the device battery. Use the plastic opener to lift, and remove, the device battery. Use the plastic opener to lift, and remove, the device battery.
    • Use the plastic opener to lift, and remove, the device battery.
  3. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  5. Use the plastic opener to pry the rear case loose. This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place. This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
Abschluss
Nick White
833 Reputation
8 Anleitungen geschrieben
Clemson, Team 13-1, Benson Fall 2013 Mitglied von Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 199
