Zum Hauptinhalt wechseln
LG Cosmos 2 Speaker Replacement
Was du brauchst
  1. LG Cosmos 2 Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 LG Cosmos 2 Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 LG Cosmos 2 Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Speaker Replacement: Schritt 2, Bild 1 von 3 LG Cosmos 2 Speaker Replacement: Schritt 2, Bild 2 von 3 LG Cosmos 2 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Speaker Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Speaker Replacement: Schritt 4, Bild 1 von 3 LG Cosmos 2 Speaker Replacement: Schritt 4, Bild 2 von 3 LG Cosmos 2 Speaker Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 LG Cosmos 2 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
Abschluss
Nick White
851 Reputation
8 Anleitungen geschrieben
Clemson, Team 13-1, Benson Fall 2013 Mitglied von Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 358
