Einleitung
Replacing a faulty motherboard is simple, but time consuming.
Was du brauchst
Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
