Zum Hauptinhalt wechseln
LG Cosmos Side Case Replacement
Was du brauchst
  1. LG Cosmos Side Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Apply an upward force to slide the back cover off.
  2. LG Cosmos Side Case Replacement: Schritt 2, Bild 1 von 1
    • Use your finger to push down on the top of the battery and pull it out.
  3. LG Cosmos Side Case Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
  4. LG Cosmos Side Case Replacement: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool to pry the rear case loose.
  5. LG Cosmos Side Case Replacement: Schritt 5, Bild 1 von 1
    • Once the rear case is loose, lift it from the rest of the phone.
  6. LG Cosmos Side Case Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
  7. LG Cosmos Side Case Replacement: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to pry the motherboard loose.
  8. LG Cosmos Side Case Replacement: Schritt 8, Bild 1 von 1
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
  9. LG Cosmos Side Case Replacement: Schritt 9, Bild 1 von 1
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
  10. LG Cosmos Side Case Replacement: Schritt 10, Bild 1 von 1
    • Use your finger to pull the flex cable out from its connector.
  11. LG Cosmos Side Case Replacement: Schritt 11, Bild 1 von 1
    • Pull the motherboard away from the rest of the phone.
  12. LG Cosmos Side Case Replacement, Silicon Keypad: Schritt 12, Bild 1 von 1
    • Lift the silicon keypad away from the rest of the phone.
  13. LG Cosmos Side Case Replacement, Side Case: Schritt 13, Bild 1 von 1
    • Remove the four 2.0mm Phillips #000 screws on the golden squares.
  14. LG Cosmos Side Case Replacement: Schritt 14, Bild 1 von 1
    • Slowly lift the side case away from the rest of the phone.
    • The flex cable can be torn if it is caught on the frame of the side case.
Abschluss
Johnny Phane
70 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-63, Johann Spring 2013 Mitglied von Cal Poly, Team 13-63, Johann Spring 2013
CPSU-JOHANN-S13S13G63
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 1,035
