Zum Hauptinhalt wechseln
LG EnV Touch VX11000 Motherboard Replacement
Was du brauchst
  1. LG EnV Touch VX11000 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Motherboard Replacement: Schritt 3, Bild 1 von 2 LG EnV Touch VX11000 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Motherboard Replacement, Volume and Camera Buttons: Schritt 4, Bild 1 von 2 LG EnV Touch VX11000 Motherboard Replacement, Volume and Camera Buttons: Schritt 4, Bild 2 von 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Motherboard Replacement: Schritt 6, Bild 1 von 2 LG EnV Touch VX11000 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 LG EnV Touch VX11000 Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Use your fingers to pull up on the tab in order to unplug it.
  8. LG EnV Touch VX11000 Motherboard Replacement: Schritt 8, Bild 1 von 2 LG EnV Touch VX11000 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Using both of your hands, gently pry out the motherboard by pulling up on both ends.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Rachel Smith
593 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-2, Forte Fall 2013 Mitglied von Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 545
