Zum Hauptinhalt wechseln
LG EnV Touch VX11000 Screen Assembly Replacement
Was du brauchst
  1. LG EnV Touch VX11000 Screen Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 2, Bild 1 von 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 3, Bild 1 von 2 LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 3, Bild 2 von 2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: Schritt 4, Bild 1 von 2 LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: Schritt 4, Bild 2 von 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 5, Bild 1 von 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 6, Bild 1 von 2 LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: Schritt 7, Bild 1 von 3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: Schritt 7, Bild 2 von 3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: Schritt 7, Bild 3 von 3
    • Open the phone at a 90 degree angle. This needs to be done in order to reach the screws.
    • Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
    • Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
  8. LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 8, Bild 1 von 2 LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 8, Bild 2 von 2
    • Pry off the two screw covers on the inside screen, using a spudger or your fingernail.
    • Remove the two 1.5mm #000 Phillips screws that were under the screw covers using the Phillips #000 screwdriver.
  9. LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 9, Bild 1 von 2 LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 9, Bild 2 von 2
    • Pry off the front frame using your fingernail.
    • The frame should still be connected to the rest of the phone by the orange tab.
  10. LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 10, Bild 1 von 1
    • Remove the four 1.5mm #000 Phillips screws at each of the corners of the phone, using the Phillips #000 screwdriver.
  11. LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 11, Bild 1 von 3 LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 11, Bild 2 von 3 LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 11, Bild 3 von 3
    • Peel off the gold tape.
    • Gently pry up the metal frame with your fingers so that the screen can be removed.
  12. LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 12, Bild 1 von 2 LG EnV Touch VX11000 Screen Assembly Replacement: Schritt 12, Bild 2 von 2
    • Unplug the connector from the screen.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Rachel Smith
593 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-2, Forte Fall 2013 Mitglied von Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 1,086
