Zum Hauptinhalt wechseln
LG Enact Screen Replacement
Was du brauchst
  1. LG Enact Screen Replacement, Battery: Schritt 1, Bild 1 von 3 LG Enact Screen Replacement, Battery: Schritt 1, Bild 2 von 3 LG Enact Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Open the back cover by prying into the bottom tab with an iFixit opening tool.
  2. LG Enact Screen Replacement: Schritt 2, Bild 1 von 3 LG Enact Screen Replacement: Schritt 2, Bild 2 von 3 LG Enact Screen Replacement: Schritt 2, Bild 3 von 3
    • Use an iFixit opening tool to remove the battery.
  3. LG Enact Screen Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
  4. LG Enact Screen Replacement: Schritt 4, Bild 1 von 2 LG Enact Screen Replacement: Schritt 4, Bild 2 von 2
    • Use an iFixit opening pick to pop out the speaker.
  5. LG Enact Screen Replacement, Midframe: Schritt 5, Bild 1 von 2 LG Enact Screen Replacement, Midframe: Schritt 5, Bild 2 von 2
    • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
  6. LG Enact Screen Replacement: Schritt 6, Bild 1 von 1
    • Use the iFixit opening pick to pry out the midframe.
  7. LG Enact Screen Replacement, Motherboard: Schritt 7, Bild 1 von 2 LG Enact Screen Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Unplug the four ports connected to the motherboard.
    • Disconnect the two wires on top of the battery.
    • Disconnect the two wires under the battery.
  8. LG Enact Screen Replacement: Schritt 8, Bild 1 von 2 LG Enact Screen Replacement: Schritt 8, Bild 2 von 2
    • Slowly pry out the motherboard using an iFixit opening pick.
  9. LG Enact Screen Replacement, Charging Port: Schritt 9, Bild 1 von 2 LG Enact Screen Replacement, Charging Port: Schritt 9, Bild 2 von 2
    • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
  10. LG Enact Screen Replacement, Keyboard: Schritt 10, Bild 1 von 3 LG Enact Screen Replacement, Keyboard: Schritt 10, Bild 2 von 3 LG Enact Screen Replacement, Keyboard: Schritt 10, Bild 3 von 3
    • Gently remove the blue metal plate using an iFixit opening pick.
    • Gently remove the black plastic from inside the battery compartment.
  11. LG Enact Screen Replacement: Schritt 11, Bild 1 von 1
    • Remove seven 1.2 mm screws with a Phillips #00 screwdriver.
  12. LG Enact Screen Replacement: Schritt 12, Bild 1 von 1
    • Remove the ribbon cable from the battery compartment.
  13. LG Enact Screen Replacement: Schritt 13, Bild 1 von 3 LG Enact Screen Replacement: Schritt 13, Bild 2 von 3 LG Enact Screen Replacement: Schritt 13, Bild 3 von 3
    • Remove the plastic half containing the keyboard.
  14. LG Enact Screen Replacement, Screen: Schritt 14, Bild 1 von 1
    • Remove the four 1.2 mm screws from the corners using a Phillips #00 screwdriver.
  15. LG Enact Screen Replacement: Schritt 15, Bild 1 von 2 LG Enact Screen Replacement: Schritt 15, Bild 2 von 2
    • Gently pry the screen open with a nylon spudger, making sure you’re not damaging the LCD or the plastic.
  16. LG Enact Screen Replacement: Schritt 16, Bild 1 von 2 LG Enact Screen Replacement: Schritt 16, Bild 2 von 2
    • Detach the two connectors from the screen and pop the screen open using a spudger.
  17. LG Enact Screen Replacement: Schritt 17, Bild 1 von 1
    • Disconnect the touch button sensors using a spudger.
  18. LG Enact Screen Replacement: Schritt 18, Bild 1 von 1
    • Gently disconnect and remove the LCD using a spudger.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 76
