Einleitung
Screens are always prone to breaking or cracking. If you need help replacing your LG Enact screen, this guide will help you replace it.
Be sure your device is powered off fully and be sure to follow all steps carefully. Also, make sure that you are safe when handling a potentially shattered glass screen as you may be vulnerable to injuring yourself.
Was du brauchst
Open the back cover by prying into the bottom tab with an iFixit opening tool.
Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
Unplug the four ports connected to the motherboard.
Disconnect the two wires on top of the battery.
Disconnect the two wires under the battery.
Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
Gently remove the blue metal plate using an iFixit opening pick.
Gently remove the black plastic from inside the battery compartment.
Remove the four 1.2 mm screws from the corners using a Phillips #00 screwdriver.
Gently pry the screen open with a nylon spudger, making sure you’re not damaging the LCD or the plastic.
Detach the two connectors from the screen and pop the screen open using a spudger.
