Was du brauchst
Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
You now have access to:
Your SD card
Your SIM card
Your device's serial numbers
Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
Pry the speaker assembly out of the phone and set it aside
Remove the remaining 6 screws securing the plastic frame to the back housing
Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
Continue working your way around the phone, prying carefully with your prying tool
When you work the frame free, set it aside
Wifi and cell service antennas
LCD connector
Back camera connector
Front camera connector
Touch screen/ digitizer connector
Charger port connector
Headphone jack connector
With a spudger or safe open pry tool, carefully detach the LCD flex connector
Release the two antennae from their connectors
Release the back camera's flex from its connector
Release the charging port flex from its connector
Release the front camera's flex from its connector
Release the touch screen/digitizer's flex cable from its connector
Lift the motherboard away from the housing, taking extra care not to snag any of the antennae or flex cables
Set the motherboard aside
Insert a small flathead screwdriver or black plastic spudger between the front silver bezel and the black plastic mid-frame
Gently pry on the bezel to release the clips adhering the screen to the mid-frame
Work your way around the phone, still using the small flathead or spudger, until the screen is fully separated
Remove the screen, taking care not to tear the flex cable that is still threaded through the housing.
Peel off the adhesive portion of the LCD ribbon cable from the back of the phone
Lift the LCD from its bottom edge and work the ribbon cable carefully through the hole
Set the LCD aside
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Just replaced my broken screen by following these directions. Back together now and all works well except the camera. I'm just getting a fuzzy gray or green screen. Took apart a second time to make sure the camera connectors were installed properly and they seem to be. Put back together again but camera is still screwed up.
Any suggestions?
