Zum Hauptinhalt wechseln
LG Escape (p870) charging port board assembly
Was du brauchst
  1. LG Escape (p870) charging port board assembly, Battery: Schritt 1, Bild 1 von 2 LG Escape (p870) charging port board assembly, Battery: Schritt 1, Bild 2 von 2
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) charging port board assembly: Schritt 2, Bild 1 von 2 LG Escape (p870) charging port board assembly: Schritt 2, Bild 2 von 2
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) charging port board assembly, Loudspeaker Assembly: Schritt 3, Bild 1 von 1
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) charging port board assembly: Schritt 4, Bild 1 von 2 LG Escape (p870) charging port board assembly: Schritt 4, Bild 2 von 2
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
  5. LG Escape (p870) charging port board assembly, Touch screen/digitizer: Schritt 5, Bild 1 von 1
    • Remove the remaining 6 screws securing the plastic frame to the back housing
  6. LG Escape (p870) charging port board assembly: Schritt 6, Bild 1 von 3 LG Escape (p870) charging port board assembly: Schritt 6, Bild 2 von 3 LG Escape (p870) charging port board assembly: Schritt 6, Bild 3 von 3
    • Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
    • Continue working your way around the phone, prying carefully with your prying tool
    • When you work the frame free, set it aside
  7. LG Escape (p870) charging port board assembly: Schritt 7, Bild 1 von 1
    • Wifi and cell service antennas
    • LCD connector
    • Back camera connector
    • Front camera connector
    • Touch screen/ digitizer connector
    • Charger port connector
    • Headphone jack connector
  8. LG Escape (p870) charging port board assembly: Schritt 8, Bild 1 von 3 LG Escape (p870) charging port board assembly: Schritt 8, Bild 2 von 3 LG Escape (p870) charging port board assembly: Schritt 8, Bild 3 von 3
    • With a spudger or safe open pry tool, carefully detach the LCD flex connector
    • Release the two antennae from their connectors
    • Release the back camera's flex from its connector
  9. LG Escape (p870) charging port board assembly: Schritt 9, Bild 1 von 2 LG Escape (p870) charging port board assembly: Schritt 9, Bild 2 von 2
    • Release the charging port flex from its connector
    • Release the front camera's flex from its connector
    • Release the touch screen/digitizer's flex cable from its connector
  10. LG Escape (p870) charging port board assembly: Schritt 10, Bild 1 von 1
    • Release the headphone jack's flex cable from its connector
  11. LG Escape (p870) charging port board assembly: Schritt 11, Bild 1 von 2 LG Escape (p870) charging port board assembly: Schritt 11, Bild 2 von 2
    • With a pair of tweezers, VERY carefully pull the volume button flex out of the rear housing
    • Repeat the process with the power button flex cable
    • The power button and volume button flex cables will tear very easily, so be cautious
  12. LG Escape (p870) charging port board assembly: Schritt 12, Bild 1 von 2 LG Escape (p870) charging port board assembly: Schritt 12, Bild 2 von 2
    • Lift the motherboard away from the housing, taking extra care not to snag any of the antennae or flex cables
    • Set the motherboard aside
  13. LG Escape (p870) charging port board assembly: Schritt 13, Bild 1 von 2 LG Escape (p870) charging port board assembly: Schritt 13, Bild 2 von 2
    • Insert a small flathead screwdriver or black plastic spudger between the front silver bezel and the black plastic mid-frame
    • Gently pry on the bezel to release the clips adhering the screen to the mid-frame
    • Work your way around the phone, still using the small flathead or spudger, until the screen is fully separated
    • Remove the screen, taking care not to tear the flex cable that is still threaded through the housing.
    • After carefully threading the digitizer and outer housing/bezel from the middle bracket you'll notice the digitizer is held on by a band of very strong adhesive - this will be destroyed when you take off the old digitizer. When you replace your digitizer you can use double-sided tape or epoxy to hold the new digitizer on the bezel.
  14. LG Escape (p870) charging port board assembly, Charging Port: Schritt 14, Bild 1 von 2 LG Escape (p870) charging port board assembly, Charging Port: Schritt 14, Bild 2 von 2
    • Gently pry the charging port assembly's ribbon cable starting at the top (marked in blue)
    • Slowly peel the ribbon cable downward until the charging port assembly is no longer adhered to the housing
    • Remove the assembly and set it aside
    • Be careful not to tear the antennae when pulling the charging assembly out of the phone
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Brad
1.908 Reputation
10 Anleitungen geschrieben
Ein Kommentar
Hi
I didn't understand why do you need to do part 13?
eli cohen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,555
