Zum Hauptinhalt wechseln
LG Flare Microphone Replacement
Was du brauchst
  1. LG Flare Microphone Replacement, Microphone: Schritt 1, Bild 1 von 2 LG Flare Microphone Replacement, Microphone: Schritt 1, Bild 2 von 2
    • Remove the back cover by pressing on the top middle raised lines of the back cover and sliding the cover off.
  2. LG Flare Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by popping the top out and removing the battery.
  3. LG Flare Microphone Replacement: Schritt 3, Bild 1 von 1
    • Use appropriately sized Philips-head screwdriver to remove the six small screws on the back of the phone under the battery.
  4. LG Flare Microphone Replacement: Schritt 4, Bild 1 von 1
    • Use an opening tool to pop the back panel apart around the edges, and then pry the whole piece off.
  5. LG Flare Microphone Replacement: Schritt 5, Bild 1 von 1
    • Use an opening tool to separate the tabs on the green circuit board from the front body of the phone.
  6. LG Flare Microphone Replacement: Schritt 6, Bild 1 von 1
    • Use an opening tool to pop the orange connecting strip off of the circuit board.
  7. LG Flare Microphone Replacement: Schritt 7, Bild 1 von 1
    • Un-clip the 2 metal clips on one side of the circuit board.
  8. LG Flare Microphone Replacement: Schritt 8, Bild 1 von 2 LG Flare Microphone Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers and wedge, remove silver piece from green circuit board.
  9. LG Flare Microphone Replacement: Schritt 9, Bild 1 von 1
    • Remove the microphone (rip soldering).
  10. LG Flare Microphone Replacement: Schritt 10, Bild 1 von 1
    • Solder new microphone in place OR buy replacement circuit board from www.ifixit.com and replace.
Abschluss
Kelsey Hanna
1 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-3, Garvin Fall 2015 Mitglied von Ohio State, Team 1-3, Garvin Fall 2015
OSU-GARVIN-F15S1G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 185
