Zum Hauptinhalt wechseln
LG G Pad 7.0 Battery Replacement
Was du brauchst
  1. LG G Pad 7.0 Battery Replacement, LG G-Pad 7.0: Schritt 1, Bild 1 von 1
    • Here it is - LG G-Pad 7.0. Let's dive right in!
  2. LG G Pad 7.0 Battery Replacement, Jumping right into action: Schritt 2, Bild 1 von 2 LG G Pad 7.0 Battery Replacement, Jumping right into action: Schritt 2, Bild 2 von 2
    • First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
  3. LG G Pad 7.0 Battery Replacement, First Glimpse: Schritt 3, Bild 1 von 1
    • Vuala! We're in! Carefully slide the screen assembly away from the back cover.
  4. LG G Pad 7.0 Battery Replacement, A Look on the Inside: Schritt 4, Bild 1 von 1
    • Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
    • Grab your * Tweezers, the best tweezers you can get!
    • Carefully pry up the charging port connection from the bottom left with your Tweezers.
  5. LG G Pad 7.0 Battery Replacement, Battery Connection: Schritt 7, Bild 1 von 1
    • Carefully lift the battery connector.
  6. LG G Pad 7.0 Battery Replacement, Disposal of old Battery: Schritt 9, Bild 1 von 1
    • After removing the faulty/dead battery, make sure you properly dispose it.
  7. LG G Pad 7.0 Battery Replacement, Don't Forget!: Schritt 10, Bild 1 von 2 LG G Pad 7.0 Battery Replacement, Don't Forget!: Schritt 10, Bild 2 von 2
    • After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • There you go! A quick battery replacement on your LG G-Pad.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
GadgetERService
1.638 Reputation
2 Anleitungen geschrieben
Minnesota Repair Techs Mitglied von Minnesota Repair Techs
Community
4 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Big thanks to the Author for this, I used it on my v410, worked perfect !
Max Haxster - Antwort
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
Mario Escobar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 15
Insgesamt: 2,571
