Zum Hauptinhalt wechseln
Einleitung
Before starting, be sure that your tablet is turned off and that your work surface is clean. This is to avoid any unnecessary scratches since your screen will be facedown for the bulk of the replacement process.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the front panel by separating the glass screen from the plastic encasing using a non-marrying pry tool. Avoid using excessive force around the USB charging port to avoid damaging it .
    • Remove the front panel by separating the glass screen from the plastic encasing using a non-marrying pry tool.
    • Avoid using excessive force around the USB charging port to avoid damaging it .
  2. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  3. Gently disconnect the camera ribbon cable from the motherboard using a plastic pry tool. Remove the rear camera from the device. Remove the rear camera from the device.
    • Gently disconnect the camera ribbon cable from the motherboard using a plastic pry tool.
    • Remove the rear camera from the device.
Abschluss
Pratik Swayamsiddha Rath
85 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G2, Wilson Fall 2018 Mitglied von IUPUI, Team S2-G2, Wilson Fall 2018
IUPUI-WILSON-F18S2G2
4 Mitglieder
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
Insgesamt: 77
