Einleitung
In cases where the front facing camera is not responding or isn’t powering on, this guide will help you replace the camera to fix these issues.
Was du brauchst
Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
Disconnect the battery connector by prying it upwards (red marker).
Remove the ribbon cables by prying them upwards with a plastic pry tool ).
Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
