Zum Hauptinhalt wechseln
LG G Pad 7.0 LTE Speaker Replacement
Was du brauchst
  1. LG G Pad 7.0 LTE Speaker Replacement, Removing the Back Cover: Schritt 1, Bild 1 von 1
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Speaker Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Remove (1) Silver 3mm PH0 screw from the speaker (red marker).
  4. LG G Pad 7.0 LTE Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove speaker from device.
Abschluss
Fadi Bitar
880 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 14-6, Eyestone Fall 2016 Mitglied von USF Tampa, Team 14-6, Eyestone Fall 2016
USFT-EYESTONE-F16S14G6
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 389
