Was du brauchst
Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
Fast fertig!
Abschluss
