Zum Hauptinhalt wechseln
LG G Pad 7.0 Motherboard Replacement
Was du brauchst
  1. LG G Pad 7.0 Motherboard Replacement, Front Panel: Schritt 1, Bild 1 von 2 LG G Pad 7.0 Motherboard Replacement, Front Panel: Schritt 1, Bild 2 von 2
    • The screen assembly is secured to the plastic backing with clips.Insert the plastic opening tool between the screen and plastic.
    • Carefully work your way around the device making sure not to go too deep damaging any eternal components, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Motherboard Replacement, Connectors: Schritt 2, Bild 1 von 3 LG G Pad 7.0 Motherboard Replacement, Connectors: Schritt 2, Bild 2 von 3 LG G Pad 7.0 Motherboard Replacement, Connectors: Schritt 2, Bild 3 von 3
    • Remove the red marked connectors by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
    • You will have to remove the metallic tape near the bottom of the tablet to disconnect the display cable.
    • Remove the three connectors marked in orange by gently prying them upwards. The cables are very fragile so be careful not to rip them.
  3. LG G Pad 7.0 Motherboard Replacement, Logic Board: Schritt 3, Bild 1 von 2 LG G Pad 7.0 Motherboard Replacement, Logic Board: Schritt 3, Bild 2 von 2
    • Remove the 7 screws marked in red that are securing the logic board to the case.
    • Be sure that all the connectors marked in orange are removed before pulling out the mother board.
    • Very carefully remove the logic board after the screws have been removed
  4. LG G Pad 7.0 Motherboard Replacement: Schritt 4, Bild 1 von 3 LG G Pad 7.0 Motherboard Replacement: Schritt 4, Bild 2 von 3 LG G Pad 7.0 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Remove the two screw marked in red.
    • Using the tweezers , gently pull out the metal bracket that holds the charging port in place.
    • Carefully pull out the ribbon connector in orange.
    • Remove the one screw that holds the speaker in place.
    • Slowly pull out the speaker.
  5. LG G Pad 7.0 Motherboard Replacement: Schritt 5, Bild 1 von 2 LG G Pad 7.0 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Insert your new mother board with the 7 screws
    • Reconnect all the connectors marked in red back to the mother board.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
echow2001
2.117 Reputation
4 Anleitungen geschrieben
LGBTQ Technicians Mitglied von LGBTQ Technicians
Community
14 Mitglieder
23 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 16
Insgesamt: 2,061
